    Dismiss Notice
Removing brass olive from shower solenoid valve
Discussion in 'Plumbing and Central Heating' started by ian_uk1975, 10 Feb 2020.
  1. ian_uk1975
    ian_uk1975
    5 Feb 2007
    42
    Thanks Received:
    Northamptonshire
    Country:
    I needed to disconnect the CW water feed from the valve and, on re-assembly, it leaked. Can't get to the olive to bodge it with some PTFE tape, as the compression nut is in the way (the short plastic stub that forms the inlet of the solenoid valve doesn't allow much room for an olive and compression nut, so the nut cannot be slid-back to expose the olive).
    The only way forwards I can see (apart from replacing the solenoid valve, of course) is to cut-off the compression nut with a cutting disc on a Dremel and then (very carefully) cut-off the olive.
    Any other ideas?
  2. ianmcd
    ianmcd
    15 Aug 2010
    14,741
    Thanks Received:
    4,985
    Lanarkshire
    Country:
    will you be able to get one of these in ?
    • Like Like x 1
  3. The Novice
    The Novice
    26 Sep 2019
    2,044
    Thanks Received:
    572
    North
    Country:
    If it’s the end I’m thinking of, gentle tapping with a hammer and slotted screwdriver may help to remove it.
    Edit: tap one side then other and keep alternating
    • Like Like x 1
  4. footprints
    footprints
    21 Sep 2011
    3,993
    Thanks Received:
    790
    Country:
  5. The Novice
    The Novice
    26 Sep 2019
    2,044
    Thanks Received:
    572
    North
    Country:
  6. footprints
    footprints
    21 Sep 2011
    3,993
    Thanks Received:
    790
    Country:
    Far better than Hawk white (which is just weak putty more or less) a silicone based leak sealing product never without it in my bag.(y)
    • Thanks Thanks x 1
  7. ian_uk1975
    ian_uk1975
    5 Feb 2007
    42
    Thanks Received:
    Northamptonshire
    Country:
    Picking one of those up tonight... my only concern is the olive might dig into the plastic as it gets pulled-off.
    • Like Like x 1
  8. ian_uk1975
    ian_uk1975
    5 Feb 2007
    42
    Thanks Received:
    Northamptonshire
    Country:
    Yeah, someone else mentioned LSX to me (about an unrelated job). Will have to pick some up.
    Only problem in this specific scenario is that I can't physically get to the olive since the compression nut is covering it and cannot be slide-back due to lack of room.
  9. Sponsored Links
  10. The Novice
    The Novice
    26 Sep 2019
    2,044
    Thanks Received:
    572
    North
    Country:
    Think it just pulls it off, no digging in. If there's any distortion to the plastic then ptfe would be the way to go on this instance (unless ls-x could do it).
  11. ianmcd
    ianmcd
    15 Aug 2010
    14,741
    Thanks Received:
    4,985
    Lanarkshire
    Country:
    No it will be fine
  12. SandyLyon
    SandyLyon
    21 Oct 2012
    616
    Thanks Received:
    137
    Lancashire
    Country:
    Plastic pipe manufacturers say not to use and type of jointing compounds, copper olive with PTFE tape if required.
    Check if ok to use on plastic.
  13. Madrab
    Madrab
    4 Oct 2012
    5,895
    Thanks Received:
    1,532
    East Renfrewshire
    Country:
    Gas PTFE tape (and that isn't a bodge BTW), 2 wraps of it around the end of the pipe and then it'll push down around the olive when it's fitted into the fitting. It's the end that fits into the fitting that needs the help with the seal as there is no twisting force to shape the faces together properly when being re-used, the nut end that's being tightened down onto the olive should form a watertight seal when they twist together.
    • Like Like x 1
  14. footprints
    footprints
    21 Sep 2011
    3,993
    Thanks Received:
    790
    Country:
    Never found LSX to affect any plastic it has come into contact with myself.(y)
    • Like Like x 1
  15. SandyLyon
    SandyLyon
    21 Oct 2012
    616
    Thanks Received:
    137
    Lancashire
    Country:
    I think it’s because plastic is an oil based product, some jointing compounds are oil based therefore could degrade the plastic pipe.
    For the same reason they say not to use oil based paints if you paint the pipes.
  16. Mike2007
    Mike2007
    10 Feb 2007
    1,276
    Thanks Received:
    32
    Cumbria
    Country:
    Angle grinder removes most stuff
Loading...
Share This Page
