Removing brass olives
30 Mar 2015
There’s been a few instances where I’ve wanted to remove/replace an olive and its always been a futile pursuit. I’ve ended up cutting the pipe and welding on a new section of pipe and with that - a fresh olive.
Can someone please advise on the process of removing used olives.
Olive remover tool does it nicely. Or cut olive to depth just before you reach copper, then snap off with screwdriver
Are you welding the pipe? Why
Thanks for the prompt response. Do you recommend a particular type/brand?
I was referring to the soldering as welding
Cut diagonally with a hack saw and then wiggle a screwdriver into the groove.
Use the jaws of an adjustable spanner set to the width of the pipe, and placed above or below the olive, then tap said spanner with a hammer.
Blup
what size are the olives ???? :LOL::LOL::LOL:
Normal size mate... My grinder is always at hand and useful for all sorts of tasks...
I used it yesterday to grind the thread off the end of a length of 12mm studded rod so that it would fit into the arbor of my 5" core cutter and act as a pilot to core cut for a flue from outside to in... Because whilst drilling a pilot from the inside to out, the face brick splayed and left a divot too deep for the normal core pilot to engage into the pilot hole and centre the core when starting the cut... Wish I'd videoed it... Worked a treat and, 5 stories up, on scaffolding, allowed me to stop swearing and get the fu©k on with the job :D
Edit: #threaded rod/ threaded stud... I'm on the wrong end of several bottles of red :p:p
Examples of alternative "olive splitters"...
