My home has a combi boiler, and still has a cold water tank installed in the loft, which supplies the toilet flush and cold taps on bath and washbasin.
I want to take the tank out, partly because it makes a dripping noise for ages after flushing the toilet or running a tap, and also to make the cold tap water in the bathroom drinkable. The extra space in the loft might be useful too.
I am planning to remove the tank, and join the 15mm cold water intake pipe to the 22mm outflow pipe, using a Wickes 3 way speedfit joint [2x22mm, 1 x 15mm] with a 22mm cap, a 15mm stick, bent to a 'u' shape, and speedfit clips.
Any advice or warnings gratefully received.
