REMOVING DOOR PANEL
8 Oct 2006
Lancashire
WISH TO REMOVE A WOODEN PANEL IN a 1920s INTERNAL DOOR, AND REPLACE WITH GLASS TO PROVIDE MORE LIGHT INTO A DARK HALL. HOW DO I REMOVE THE PANEL PLEASE.THE PANEL PINS SURROUNDING PANEL LOOK VERY SML. WITH LITTLE TO GRIP. I AM A D.I.Y BEGINNER. ANY HELP APPRECIATED
_____________________________
Lynda, moderator
please do not SHOUT see forum rule 6
heeellloooo malter and welome :D:D:D:D:
if its a unmodified door the panels will be fully captive and wont have beading as in the panels are fixed within the door structure and what looks like beading is actualy a molded edge on the rails and styles
if you do require to remove a molded panel easiest is a router and strait edge
select your replacement moulding router out 1mm deeper than required[into panel] and along an edge so the replacement moulding will line up through the glass with the origional line clean out corners with a chisel
another point to add is router out the molding on the side that you least look at or least obvious for normal use
bobs your uncle :lol:
For safety reasons, the glass panel in the door should also be toughened glass.
Maxxy said:
I think someones been watching the abc1 channel today :D
not quite i only get freeveiw :wink:
did they deal with that subject yesterday then!!!!!!
well for a bench joiner you would expect me to get it right :roll: :roll: :roll: :D
how many points out off 10 would you give me for my method descripton then ----------7 out of 10!!!!! :D
