Removing emulsion from sandstone
7 Apr 2007
Yorkshire
I am decorating my main bedroom which has an old Victorian fireplace. The surround is made from sandstone and has several layers of pain and varnish that I wish to remove to restore the stone surround.
I have used a paint stripper to get the top layer of paint and varnish off. However, the first coat over the sandstone appears to be an emulsion and it doesn't want to come off with my paint stripper.
Does anyone know if and how to remove the remaining paint quickly and easily?
Cheers
Nathan
Problem prob is that the first coat of "emulsion" has sunk into the sandstone.
You culd try a stone and brick cleaner such as 'dis-clean'
Failing that...scrub with very hot water.
I'm in a slightly similar position with sandstone sills on the outside of the house - they've been painted with something (gloss, masonry paint - I've no idea).
I have considered maybe sandblasting them to remove the paint.
Well, in the end I used a paint stripper which removed the top layer(s) or paint and a layer of varnish. Then I removed the bottom coat of paint (which I assumed was emulsion that couldn't be removed easily with the paint stripper) by using some drain cleaner (e.g. a caustic solution). Working in small sections, I applied with a cloth and scrubbed with a nail brush, and removed with water. I did this several times, and have managed to get all the paint off - took me about a day. All that remains is a slight haze of white from the emulsion - but i expect I can get this off by a couple of further washes with crystal clean water and a bit more scrubbing.
It'll look nice with the Victorian fireplace once I've stripped off the black paint back to the metal underneath!
Cheers
