Removing filter on Franke 3 in 1 tap
30 Jul 2004
I have 3 in 1 tap by FRANKE which has got a filter and I am unable to open the filter which us made if plastic and has like thread in on and off.
It has a rubber sill.
Can anybody suggest how to go about.
Many thanks.
Hi, thank you for your response.
I emailed FRANKE and they said they are going to list a spanner which is not on their website yet but would be cost about £15.
If I use rubber strap wrench to open it, do you think it might open it as I don't intend to damage it and run into to another problem.
Sorry to bore anybody reading this as it is steep to pay £15.00 for spanner whereby the taps and hot water system cost around £800 beside filter costs about £39.95 every 6 months.
The filter cartridge housing,sometimes called a sump.Is designed to be unscrewed by hand just grip it with both hands and turn anti clockwise it will unscrew.The actual filter cartridge is usually also screwed,again turn anti clockwise. :idea: Make sure water is turned off.
There is also a chance the sump has been over tightened during installation,just needs a good turn with both hands or use a boa constrictor strap wrench.
:rolleyes:
You need a man with a strong right hand, try and find a married man. His right hand will be much stronger.
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Andy
