Removing grass without removing grass
17 Jul 2010
Tyne and Wear
I'm looking at putting artificial grass in the garden as it gets sodden and puddles in winter months.
Given that I also want to increase the level of the grass to match the patio (about 50-100mm) I'm wondering if I can kill the grass off with weedkiller and coverage over the winter and then increase the level with compacted hardcore and sand blinding instead of needing to take the top layer off, which will be a mountain to remove and replace the void.
Any advice on whether this is acceptable/possible appreciated.
Thanks.
If you cover with weed suppression sheeting it will kill off any grass .
I adjusted my levels with sharps sand .
Plastic grass won't stop your garden flooding -- issues like that are caused by the makeup of the soil underneath your lawn. Rather than destroying a source of food and nesting material for the local wildlife, why not sort the drainage issue out? Lots of options for doing it; my particular choice being to raise the lawn by 100mm after digging trenches for an extension. The additional soil holds water but I could have installed a drainage system.
