Removing load bearing wall padstone problem
18 Apr 2014
Birmingham
Hello.
Im just about to buy my padstones for removing the load bearing wall with an RSJ.
My SE has speced 215mm deep Padstones (450x102x215)
The problem I have is if I fitted this size padstone I will need to shim up / pack the padstone up around 80mm for the RSJ to rest on top of it.
This doesn't feel right.
Atm Id be removing 3 courses of brick to get the padstone in.
Is this normal or does a different size padstone need to be used?
23 Feb 2012
Manchester
Can't quite understand; how deep are your brick courses?
Normally a 215 deep block will need three courses of brick removing - are your courses much deeper?
18 Apr 2014
Birmingham
They must be. If I where to remove 2 courses then There wouldn't be enough room to install my 254mm RSJ. and a 215 block
If I where to remove 3 courses then Id need a padstone around 270mm deep to get close to the RSJ without excessive shimming
23 Feb 2012
Manchester
254 deep seems a big beam; what is the span?
We usually use shallower padstones cut from lengths of pre-cast concrete lintel (140 deep).
8 Jun 2010
Lancashire
It seldom happens that the pad is sat on a full brick/block course.
You need to put a split brick/block under it (the padstone)
18 Apr 2014
Birmingham
ok sound. Is it possible to buy half high bricks. I can imagine splitting them down neatly to be quite tricky.
The other soiltion I though about is a 280mm deep padstone which might fit. I need to messure again.
Id think this would be alright as its even bigger.
The beam is spamming 4.2M but is also the supporting RSJ for a connection when I remover a twin layer external wall for in the future.
18 Apr 2014
Birmingham
Ok sound. Ive gone with a 215 deep padstone and Ill put a rip of half thickness bricks in :)
Thanks for the help
