Removing lockshield valves from a radiator
28 Sep 2004
Hi Folks,
I've moved into a new house recently, and I've been replacing the radiator valves with new TRVs and lockshields. Some clever soul removed all the thermostatic heads :roll: and having drained the system down I figured I might as well replace the lockshields as well.
My problem is that I can't get the connectors between the radiator and the lockshields out. Turning the nut causes the lockshield to rotate but the connector doesn't move.
Any suggestions?
Cheers
John
Hold the valve still and turn the nutas though you were screwing it into the radiator - which will be the other way from the direction you've been trying. The nut stays loose on the bit in the rad.
Then you use a key to get the part out of the radiator. There are several, the simplest being like a big allen key. Some taper to accommodate different sizes, and some have slots for keyways etc. You CAN undo them with a pair of grips in the end, but you'll need something decent to get the new ones in - (unless you go with the ones with a square on the outside of the tube. I'd advise against those because its harder to get the rad off when you need to.)
I remember wheb I first came across them I used a cold chisel which had a hex shaft. You'll see examples on the Monument-tools site.
Thanks for that ChrisR, had a look inside one of the radaitor connectors and found the fitting for a hex shaped key.
Cheers
John
