removing one leaf of a thermal block cavity wall
25 Sep 2012
Kent
I want to put a pocket door into an existing internal, thermal block cavity wall, with an existing doorway. I'm thinking that if I remove just one side of the block work next to the door, I can fit the frame and replace a stud wall in it's place. Would I need a lintel or would the other side of the cavity wall be enough?
Any thoughts would be welcome, as there seems to be no information about this on line.
Ron
it's unusual for an internal wall to have a cavity; are you sure of the construction?
what is upstairs?
Yes. I have the plans showing this. The wall is 300mm thick. The house is a Chalet bungalow with 2 bedrooms upstairs. The door goes into a utility room, that although all built at the same time, is a single floor, like an extension, so the wall was designed as an outside wall but I think both leaves are thermal blocks.
You will need a lintel longer than the width of the opening on one leaf, unless you are going to prop the leaf to install the gear in the cavity and then rebuild - but some systems may not fit in a narrow cavity.
