I'm planning to use an SDS drill to remove a load of plaster (hall and stairs). I'll need to buy some kind of bit. What's the best to use? I've seen flat chisels, spade chisels and this chap even uses a tile lifter. Or maybe it doesn't really matter?
Thanks,
wrathkeg
If the plaster is not well stuck on, a lump hammer and narrow chisel can prise behind and work across. You can lever off quite big chunks relatively easily.
SDS will work well of course if well stuck, but can be fierce and damage bricks too, so one to watch.
