removing wires from switch
4 Jul 2003
I am trying to install a dimmer in my new house. the problem i have is that i can't seem to remove the wires from the existing light switch. they aren't wound around the screws on the switch like i am used to seeing. they are inserted in holes in the back of the switch. the switch has an engraved instruction to press here to release wires, but i can't seem to get it to work. is there a trick to it?
we do not have those type of connections here in the U.K. why not just cut the wire off close to the switch as you can? Obviously with the electricity off
Turn off the power. Get a very small flathead screwdriver (like one for repair of eyeglasses). Above the wire is a square hole. Put the flat end of the screwdriver in the hole & push. At the same time you are pushing the screwdriver in, pull the wire out of the round hole. This type switch is usually legal for 14ga. wire only. It is best to rewire the new switch using the screws. If your house is over 10 years old it probably has the larger 12 gauge wire.
Mark
