Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Need to redo some brickwork and render in drain pit
I've got waterproofer can I use extra fast set cement with this
As I need it to harden by the evening ?
When you say "drain pit" do you mean inspection chamber? Put a couple of pics up. You can use quick set to repair pipes that are live and patch up cracks in pipes with it and it "goes off" very quickly.....
Make your bricking mortar ( 4-1 and some W/proofer in the mix )so it will lay your bricks and you can render (brush) over them and do your flaunching with the same mix and use a brush to shape it how you want.. Try to do all the work in one "hit",,
