It goes up to two bricks thick only where those buttresses are.
This is why I am concerned about the missing pointing, in places on my side it has fallen out to a depth of an inch or more so there is effectively only 2-3" holding the wall upright. I think in this condition it will start to lean and then fall over.
You can't cut out the spalled bricks without damaging the rendering then.
Probably best to re-point it and see what it looks like.
Rendering often fails on old brickwork. If it does fail and crack you can't go back to the face work, whereas if you re-point and don't like it you can always render it.
If I was going to use render I would probably pebble dash it.
Cracked rendered garden walls look a mess, whereas old damaged face brick walls can add character to the garden.
That sounds like a good course of action - I guess the re pointing needs doing whatever the final outcome.
The job is going to be delayed now as when I was removing the soil piled up against the wall I accidentally disturbed an old well, complete with about 8ft of crystal clear water!
If you render a damp wall, which has blown bricks etc , its a bit like adding two (or three) sheets of glass. Each one is not moisture permiable and with capillary action, any one will draw water up and come off in time.
Better to add a breathable lime base render, and I saw a good version on youtube whilst looking for the same answer for a house wall.
stone wall coating, stucco, grand designs I think.
They actuially finished the wall to look like bricks too???
To me that wall is a selling point. If it is original it's condition would not de-value your home. Personally I think it looks great and agree with those that advise you to try repointing first. If you render and it fails imagine how the remaining render will spoil it .... and all the work involved in removing it.
