Good morning all,
I need to reduce a door opening in an external, single skin block wall by around 8" and try to match into the existing external render without a join that is too obvious and unsightly.
The easiest way would seem to be 4' x 2" stud clad with 12 mm wbp plywood. I have some rendering mesh if that would help. The question is: can I render plywood?
Any suggestions or advice would be much appreciated.
