Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Can anybody recommend the best product to use to join and disguise the repair on broken granite. The colour is a dark grey, quite speckled, with 3-4 main colours. I can get some of the ground material if it helps. I could put a photo
Ask your local stone worktop fitter, they use a clear epoxy to join the tops that is tinted to suit nthe stone. and then ground & polished I.ve had a heavily veined marble top done and you would not know (well the client has not seen it )
it's my own personal technique than involves a little rotary tool with a special blade to widen the crack with, and then filling it with epoxy glue to match the color. After proper curing (24 hours), you have to sand it flush with the surface of the stone, and use finer grit until you get a finish as close to factory as possible
