Repairing Bricks Around Window Before Plastering
13 Jul 2018
Hi ,
Im in process of remodelling bathroom. i had to take it back to brick due to many issues.
When i cleared all the blown plaster some of the bricks on the internal wall (cavity walls) below the window were loose as you can see with the crack. What do i need to do to prepare the wall for dot a dab plaster. Do i need to remove bricks one by one and reset them?
I know how to replace the sill board with expanding foam etc. What about around the window there are a number of loose bricks .
How do i fill the cavity for the plaster board to take too. The top bit has old lathes which i will remove. how do i fill this bit.
Thank shaun
