Hello - I have owned a 1930s Edwardian semi-detached house for about eight months. It is a very standard layout: when you walk in the front door, the stairs go up to the first floor along the outside wall, the corridor next to the stairs goes back to the kitchen, and the front and rear lounge are off to one side.
The house still has its original floorboards. There is a substantial crawl space under the house (2ft under the corridor and stairs portion, deepening to 4ft under the lounges), but this crawl space is tricky to access - you have to go under the stairs and the hatch is tight.
When I first moved into the house, I noticed that some of the floorboards at the base of the stairs felt a bit bouncy - they make noise when you walk on top of them (I can only describe it as a sort of "banging" or a "crunching" noise) and they don't feel 100% sturdy - not ready to collapse, but not rock-solid either.
I have two goals with the house: I want to insulate the ground floor from underneath and I want to put in a new floor. The couple up the street (identical house) actually just put another layer of flooring right on top of the old, original floorboard and I might give this a shot, too.
The other day I finally got into the crawl space and inspected the joists that were making the funny noises. I saw what looked like water damage (there was a wavy line of discolouration, kind of silvery on the wood) probably about 18in or so long on three or four of the joists. There must have been a leak or a flood at some time in the past. From knocking on the joists, however, they don't feel rotten. They feel as sturdy as ever, but they sound a bit dodgy when trodden upon.
Thanks for getting through all of this! Here's my question: I've read in several cases how people have just reinforced the joists by bolting supplementary joists to both sides of the ones that are already there.
Is this solution practical and straightforward to do? Will these additional joists not be too heavy? Should I get a professional in to do this or is it easy enough to do on one's own? If the surveyor neglected to pick this up (I paid for a full structural survey), would I have cause to raise a legal case against him?
Many thanks and kind regards
