Wish people would stop talking about plastic like it’s just one thing
Examples of plastics that solvent weld works well on: PVC, ABS
Examples of plastics that solvent weld does not work on: HDPE, LDPE, PP, PTFE, POM, PA, PC, PET, PBT, TPE, TPU
If you want to assess whether it will work for you, dab a small amount onto the work item somewhere inconspicuous, wait 30s to a minute then gently scratch at the area with a sharp implement. If the glue comes away contaminated with the colour of the plastic then it has successfully dissolved the surface and will work. If it just comes off again the same colour it went on, you need something else
Do a test first; loading up a joint with glue that just won’t work contaminates the joint making it harder to use a glue that will work
