Replace an Air Push button with a handle on Cistern
24 Apr 2008
UK, Wittering, West Sussex
I see from an old forum thread in 2015 suggested replacement pushbutton with a cable pushbutton
We have a comfort level cistern - and the cistern looks exactly like this
I have done quite a bit of work on a 2nd one we have , changing height etc , and also pulled out the drain mech and replaced washers before
so a handle would be better if there is such a thing, but i guess if i can just replace the drop valve and not have to change the front panel - that would be good , if the new one just happens to fit the hole -
thanks
You do get flush valves with handles, but they aren't compatible with the push button type. You'd have to change the complete valve.
Thanks , are the drop valve thing all standard size fittling - i know this cistern, valve just twists out
i will have to think about the hole we have now - much larger and goes over the bit thats missing at the top of the cistern
This might help you convert to a new fluidmaster cable flush valve, but check all sizes.
&hvexpln=0&gad_source=1&th=1
Andy
That would work, everything is black now handles etc - so thanks for that
Are the flush valves all standard size - so a direct replacement for the one i have
oh dear , so now i'm replacing the whole thing and pipework to the toilet -
I guess the holes in the bottom pf cistern are all different too and so a new cistern
No, they are standard 1/2" or 2" and most new flush valves will fit ok.
