Double glazed window unit(non opener) has failed and has condensation internally.
I Removed internal beading and found window fitters never used any packers.
Removed sealed unit from double sided glazing tape and it appears there are no drain holes.
Is this correct?
Is the double sided glazing tape supposed to keep all of the water from entering which would indicate why there are no drain holes.
Window openers either side do have drain holes.
Is this correct?
