Replace hive (CH & HW) with mini Combi version
17 Nov 2005
Manchester
Hello,
My Hive has packed up, we currently have our old version which controlled the CH & HW but we have had a new combi boiler fitted it was working just using it for the CH but has since failed. I have bought a new setup, hub, mini and receiver combi version.
Looking at the receiver bracket it looks the same but the wiring will need changing slightly I understand, the receiver can be isolated via a fuse spare. Does anybody know the changes I need to make please?
Thanks all.
Hive and Wiser single channel have volt free contacts, and the twin and triple channel has 230 volt contacts so if you have a link wire L to 1 than yes you can use the twin version, if not then no it is likely the boiler control is 24 volt and you will damage the boiler.
If you still have the dual channel and have bought a single channel version then there’s a bit of a change. Is the receiver next to the boiler? What model boiler?
Can you show us a picture of the wiring of your existing backplate?
You will probably have to move the wire in terminal 4 to terminal 3 and add a short link wire between L and terminal 1.
But a photo should confirm.
The existing stat is a dual channel Hive.
The OP wishes to change the stat to a single channel one, now the hot water controls are obsolete, after the installation of the combi.
