- Joined
- 27 Jan 2008
- Messages
- 29,637
- Reaction score
- 3,665
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Sure I have seen that picture before, seems odd 4 wires used, not seen the N/C contact used with wall thermostats, with tank thermostats yes, but not wall, and of course naughty using the green/yellow for anything but earth.
I would want to find other end of cable.
As to thermostat on table next to chair did that with mother, but used a cheap thermostat which lost RF link in the end. However odd as it seems on a tea trolley 3 foot from radiator worked well. But on side board 90° from radiator failed with a massive hysteresis, so position in relation to radiator very important.
I moved to programmable TRV heads in the end.
This house I use Nest, not perfect mainly due to location, but so easy to use, big dial, big display, and it learns what you want, bit late now, you already have one, but for the elderly it is so simple, and you can if you both have internet check all is OK from your home.
