Hi, I currently have a horstmann diadem, which is working fine but we want to replace it with one that provides a bit more control.
It is wired as per the wiring diagram, terminal one goes straight to the boiler live, and terminal 4 goes to the thermostat, then comes back to the CH pump live. There are no other connections, only HW on and CH on. We do have a cylinder stat and a (I believe) a 2 port valve (I can get part number/photo if needed). Live goes to the stat, then comes back to the valve, but no connections are made to the boiler control unit.
The thermostat has only two wires.
The queries I have are
1)If i buy a replacement control unit (eg http://www.screwfix.com/p/danfoss-fp715si-programmer/63760) then can i simply change the two wires currently wired to HW on and CH on to the new terminals on the new programmer for HW on and CH on, and ignore the terminals for HW off and CH off since both the on functions are normally open?
2)Does it matter that the cylinder stat is wired in this way? It is actually wired into one of the 10 way junction boxes, just that all the terminals are unused other than the L N and E as mentioned above. It seems i have a C plan, just not wired that way?
3) Also want to replace the thermostat, looking at the danfoss ret2000b, which is 2 wire. The instructions for both the control units mention switch ratings of 3A or 2.5A depending on model, does the thermostat need to be the same ratings, or not as its just a one way switch in essence?
I actually want this one: http://www.screwfix.com/p/flomasta-25902sx-two-channel-programmer/3439g anyone have wiring diagrams for this, and if so, can i wire it as per question 1 above? Only info i can find is that this fits a standard UK backplate, so i assume this is 3 = HW on and 4 = CH on?
Thanks, i can provide any more info as required, but i have tried to include as much as possible this time!
