Replace imperial hinge with metric?
8 Aug 2006
Nottinghamshire
Hi, I need to change the 16 inch side hung hinges on upvc window.
The nearest I can get some is from Screwfix but they are metric and and 1 cm longer.
Will these be ok or will I have a problem?
Thanks for any advice.
Gerry
15 Sep 2017
S. Uplands
They may be called 16 inch, but I bet they are sll really metric, its just that any particular make will be slightly different.
Since friction stays fit in a euro groove, the length doesnt matter.
Its likely they will fit and work ok, it depends whether the replacement has a similar opening action.
If the window opens 90 degrees and is egress then you need a different hinge
8 Aug 2006
Nottinghamshire
Hi Notch7
Many thanks for your advice.
It is not an egress window so I shall get some ordered.
Gerry
