I have laminate flooring in my bedroom. I built my own bed into the bedroom, so if I end up knackering the floor then it will be a real job replacing it: disassemble bed, disassemble floor... Gagh
Yes the skirting has been fitted since. It is 2 pieces that have some water damage after a leak. Luckily it is in the door area, so I'm thinking of breaking them to get them out and then trying to knock the 2 new pieces in length ways after removing the door plate. If that doesn't look like it will work, I may try to remove the 'clicks' and glue in the 2 new pieces.
