I have a 60A service fuse and 16mm tails from cutout to meter. I have 25mm tails from meter to isolator and from isolator to CU.
I paid the DNO to move the overhead supply cable to underground. They would have replaced the fuse with a 100A at the same time, but didn't because of the 16mm tails.
DNO told me an electrician needs to change the tails. An electrician told me the DNO needs to change them. Looking around, I believe my supplier (Bulb) owns these tails. Is that correct? Are they likely to change them to 25mm if I ask? Will they charge to do so?
Cheers.
Cheers.
