replaced Conservatory roof with solid roof, how to insulate
29 Sep 2013
Leicestershire
We have replaced our old polycarbonate conservatory roof with a new solid tiled roof.
We now have to finish the interior and install the ceiling plasterboard but first need to insulate.
I want to just use normal loft insulation rolls but I'm not sure how to install it as I presume its going to drop out when we fit it before the plasterboard goes up.
Can anyone give me any tips.
Thanks....
As you start fixing p/board at one side of the ceiling, fill each trough with insulation, I assume you have head room to get up high enough, otherwise staple garden netting (thin plastic type) to the underside, or drape between ties on top, lay in your insulation before fixing p/board. The secret is to only cover an area two ties wide, fit the insulation then one row of p/board...pinenot :)
