- Joined
- 4 Feb 2007
- Messages
- 40
- Reaction score
- 3
- Country
Hi
I noticed I wasn't getting hot water, so manually opened the motorised valve so would get flow when CH was on until I could get a new motor.
I have a Honeywell metal motorised valve and replaced the syncronous motor with a universal Drayton motor. It fitted fine, but has not solved the problem.
I have a Drayton cylinder stat, and used to be able to hear the valve operate as I upped the temperature on the cyclinder stat, but this is not happening, so I am assuming that replacing the motor did not fix the problem.
Any thoughts on what might have happened.
How to I check the cyclinder stat is working, its an old mechanical unit and clicks OK when operated manually. I think there are two wires from the stat, that goes to a choc bloc in a terminal box that connects with the motorised valve.
