    Dismiss Notice
Replacement boiler
Discussion in 'Plumbing and Central Heating' started by Bleakers, 15 Sep 2021.
  1. Bleakers
    Bleakers
    16 Jan 2021
    23
    Thanks Received:
    3
    Country:
    Good evening gentle folks,
    I have currently an Alpha CB28 which is frankly getting a bit old. (Aren’t we all) It’s in need of another diverter valve as the radiators are heating when running the hot water. This would be its 4th, but the last one has lasted about 8 years. However I think it’s time it went.
    I have had my regular plumber suggest a Glowworm Ultimate 30c and he has said it comes with a full 10 year warranty.
    Size wise it’s got capacity, 30kw versus 28kw, so my question really is whether it’s a reliable practical unit.
    Worcester Bosch may be a better brand, but unfortunately both my neighbour and son have had significant problems with their units, so much so that WorcsBosch have just replaced my sons and it seems to be developing the same faults, so despite the brand am a bit put off.
    Suggestions and comments are welcomed.
    Thank you all in advance, this forum previously helped me with a Hive fitting question for which I was grateful.
    Cheers
    Steve
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    13,218
    Thanks Received:
    3,023
    Daventry
    Country:
    The GW will be OK, not the best but decent. I'd mark it down on having a fairly poor heat modulation range of 4:1 with a high minimum output of 6kW, the inability to configure it to run on the system it's fitted to, an aluminium heat exchanger which is inherently more sensitive to system water quality than something with stainless steel or copper waterways, and the fact that if you as a homeowner were to call them out under warranty they'd charge you £90 before attending (which you get back if they decide it is a warranty fault, but always the risk they won't refund it).
    Good choice on avoiding WB. They aren't a better brand, they're just better at marketing. Spend millions of pounds a year on telling people you're the best, and they'll start to believe it.
    Have a look at Intergas - my brand of choice over the last 8 years which I've had great success with. 12 year warranty on the Xclusive when fitted with the Intergas system filter, no pesky diverter valve to keep failing as they've designed it out, only 4 moving parts in total. Good modulation with a minimum output of 3.6kW (minimum output is important with combi boilers as it helps with heating system efficiency), compatible with high efficiency OpenTherm controls, large bore copper waterways inside the heat exchanger, all metal internals (a lot of "premium" brands use plastic and rubber instead of brass & copper now), and very well laid out internally for ease of maintenance.
  4. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,436
    Thanks Received:
    920
    Durham
    Country:
    Add me as an Intergas fan- very simple internals, very quiet, very flexible (can run open vent or pressurised, up to you)
  5. bernardgreen
    bernardgreen
    3 Nov 2006
    25,565
    Thanks Received:
    2,550
    Bedfordshire
    Country:
    but still ( like some other boilers ) has that lump of aluminium to heat up before any heat can reach the DHW heating coil when a hot tap is turned on.
  6. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,436
    Thanks Received:
    920
    Durham
    Country:
    Yup. But I'll live with it. Once I get the bathroom finished I'll do some comparisons- cost to heat the thermal store (hot water via plate hex) Vs cost using combi water. Setup is kitchen & utility use combi hot, bathrooms use hex hot by default, can switch to combi
  7. muggles
    muggles
    28 Oct 2005
    13,218
    Thanks Received:
    3,023
    Daventry
    Country:
    Yep, which takes very little time at all (and using the smart self-learning preheat isn't even necessary).
  8. Bleakers
    Bleakers
    16 Jan 2021
    23
    Thanks Received:
    3
    Country:
    Many thanks for the replies..... Our currentAlpha takes a long time to feed the hot tap, not least because it’s location is some distance, but a little intrigued that some combi’s take longer than others to supply the hot water? So any that are known to take longer are unlikely to be top of the list. So was that a de-merit for the Intergas.
    We previously had a Vaillant combo which ate three heater matrixes, so not keen on them too....
    Not heard of Intergas boilers before, I’ll have a look.
    Steve
  9. bernardgreen
    bernardgreen
    3 Nov 2006
    25,565
    Thanks Received:
    2,550
    Bedfordshire
    Country:
    which I understand burns gas from time to time to keep the heat exchanger warm even when no heating or hot water is being called for.
    The smart self-learning function apparently gets used to when hot water might be needed and turns on the gas to pre-heat the heat exchanger just in case hot water will be required.
    Of course I could be wrong.......
  10. Sponsored Links
  11. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,436
    Thanks Received:
    920
    Durham
    Country:
    Think that's the plan, not used that feature-boiler is 4m pipe run from kitchen tap. OP to give you a clue, the thing fills a deep sink (not Belfast deep) from cold in 2 minutes, if you fill the sink it's at washing-up temperature (that's with dhw temp set at 50)
  12. muggles
    muggles
    28 Oct 2005
    13,218
    Thanks Received:
    3,023
    Daventry
    Country:
    No, they don't take longer, they're very quick. You can safely ignore Bernard's ramblings, he's not an installer nor an owner of an Intergas boiler (or indeed any combi boiler). Much of what he posts on here has either been extracted from Google or based on snippets of half-remembered information from previous threads.
    • Thanks Thanks x 1
  13. bernardgreen
    bernardgreen
    3 Nov 2006
    25,565
    Thanks Received:
    2,550
    Bedfordshire
    Country:
    but I now know the ex-owner of an Intergas boiler, ( 5 years and then replaced by another make ) and installers tend to be biased as to which boiler ( manufaturer ) treats them best
  14. Mr.B
    Mr.B
    5 Oct 2019
    211
    Thanks Received:
    34
    Country:
    All of which goes to prove what, exactly?
  15. petit_pablo
    petit_pablo
    18 Nov 2007
    9,258
    Thanks Received:
    1,906
    Lincolnshire
    Country:
    Personally, i recommend and fit Ideal boilers. Preferably the Vogue model. Stainless steel heat exchanger as opposed to most with alu and 10-12 year warranty depending on who fits it. So far ive never had a Vogue go wrong on me.
  16. bernardgreen
    bernardgreen
    3 Nov 2006
    25,565
    Thanks Received:
    2,550
    Bedfordshire
    Country:
    Proves nothing but supports the idea that Intergas may not be what the customer needs. Why would a house owner dump a 5 year old boiler ?
  17. Bleakers
    Bleakers
    16 Jan 2021
    23
    Thanks Received:
    3
    Country:
    Hi, so votes for Intergas and Ideal vogue, and the Glow Worm coming in as dependable but not the best? And definitely not WB the or Vaillant...
    Thanks for your comments so far.
    Steve
Loading...
Share This Page
