joe-90 said:It would seem to me that you need to sort out what's wrong with this boiler before you buy a new one. I would guess that the cause of your problem is either a pump that is failing or your pipes and rads are full of magnetite (that won't simply wash away). If you just go ahead and change your boiler - you may find that the fault is still there when you fire it up.
If the radiators/pipes are full magnetite, could I expect any discolouration of the water when bleading (or disconneting a pipe and letting the water out from the actual pipe)?
