I am about to replace a "Pacific" WC cistern valve (Wicks WC)) with a WRAS "Macdee" double flush valve supplied by Polypipe of Wigan. This is a direct replacement as the "Pacific" is no longer available. Fitting is very straight forward except that the valve to cistern sealing washer is quite hard plastic and does not seem to be soft enough. The installation note specifies no sealant should be used to avoid damage to the plastic components. personally I think it will be necessary, what do you think??
Cheers
Cheers
