replacement hinges for fitted wardrobes
18 Feb 2006
Birmingham
Hi all
Got some fitted wardrobes and missing some hinges.
Anyone got any ideas where I can get replacements?
The frame seems aluminium.
Picture attached
Thanks in advance
What's the picture for? does not show hinges?
Sorry, the picture I took for hinges for some reason came out blurred.
These white fittings are broken on a few doors as well, but not sure where I can purchase replacements from
Some better pictures.
Hinge on door looks like a kitchen cabinet one, but its the white fixture on the unit I have no idea of, and I am missing 2 which need to be replaced
These look remarkably similar (in function, at least) to the standard kitchen door hinge, of which the DIY sheds have a few on show.
If you look at the Isaac Lord website, you may get a little closer.
John :)
John :)
Thanks john,
Will take a look now.
Door side, the round socket that the hinge fits into should be one of two standardised sizes......frame side, if thats hollow aluminium it should be straight forward enough to fix the hinge with self tapping screws, if the bracket hole sizes differ.
John :)
John :)
They are not as big as kitchen ones, so going to buy a few 26mm hinges.
Frame side has a bracket with 2 holes pre-tapped for what looks like machine screws.
TBH I want to remove the units as they are cr4p, but just need to sort it out as want to rent out the place. I'll remove them next year andplaster the walls then
