replacement procedure
25 Jan 2009
Hampshire
can anyone help me please I need information on how to replace a radiatior ( replacement procedure )for a conventional system and a pressurised system, including ensuring it is fully operational again......PLEASE HELP. :rolleyes:
I think you need to find out exactly what system you have before attempting this.
Search FAQ's for all the advice you need ;)
Are you re-using the existing pipework, such as taking the radiator off to decorate?
If so:
1) Close both rad valves, if you have a TRV make sure you use the decorator's cap or it might leak. Take a note of the number of turns required to shut the lockshield valve.
2) Open the bleed screw.
3) put baking tray or similar under one end of radiator, undo nut between radiator and valve and drain the water out.
4) same the other end.
5) lift radiator from its brackets, immediately tip up into baking tray, you don't want magnetite sludge on your carpet.
6) do whatever you need to do while the rad's off.
7) re-hang radiator and do the nuts up.
8 ) close the bleed screw.
9) open the radiator valves - the lockshield valve by the same number of turns needed to close it.
10)bleed radiator.
11 (sealed system only) top up the pressure to 1 bar using the filling loop.
If so:
10)bleed radiator.
pleeassee :rolleyes:
are you trying to become a plumber?
why do you want to know what to do with 2 different systems?
it seems that the advice of reading the relevant faq and wikis would be a good place to start
might as well explain to us what you are trying to achieve
It sounds like a student just starting a plumbing course who has been given some homework and wants to save looking it up himself ( and doing all the additional learning in the process. )
Tony
