Replacement push button flush, 62mm hole
2 Dec 2013
Dear Experts,
I have a concealed cistern with a push-button pneumatic flush. Unfortunately last time I used it it broke with some parts of the button falling inside the partition wall! Extracting those bits would be difficult, and if I could a lasting repair might not be easy, so I am hoping to replace just the button. It's not dual-flush. The two questions are:
- Can I get just a new pneumatic button, without the cistern flush? (Do they all need the same amount of air?)
- Can I get one that fits the same 62mm diameter hole in the tiles? Some buttons that I've seen online do mention a size but I suspect they're not the hole diameter. I think 62mm is relatively large.
If necessary I can replace the bits in the cistern. If absolutely necessary I could make the hole in the tiles larger. I obviously can't make the hole smaller! What do you suggest?
