Replacement radiator valve
19 May 2005
Sussex
Bathroom rad is a cast iron job with a tap style valve each end. One is rattling and leaking when its on and won't stop closed, it just keeps winding in the clockwise off direction. So the rad is off atm. Because of the location of the pipework - in screed - to take a look at the valve I have to drain the system.
So I'm figuring, assuming I can't fix the valve I would like a reserve valve to replace the existing one. I'm not 100% sure of the flow but I think the broken valve is the inlet valve. Both taps are the same however.
I don't mind replacing the valve with one that doesn't match. I'd quite like a TRV, but the fittings are different sizes. The pipework is 15mm and there's currently a compression fitting on that, but the rad end is 22mm (I think...)
Is that a standard valve size? I can't seem to find any thing of that size or anything like it is around the £100 mark!!! Might the rad end be imperial size?
Any comments much appreciated, cheers.
:D
where in Sussex :?: I might just have a pair of old style valves from a towel rail .......then again I`ve got to find them in the "store" :oops:Chrome 3/4 inch if I remember right :?
Hi Nige, I'm in Robertsbridge (East Sussex) but I don't mind going for a drive ... How much ;) Is the inlet 15mm :?: there's not mushroom to play with connectors...
Cheers!
:D
Checked again and it looks like its a 1 inch fitting - any ideas where I can get a one inch valve?
