Replacement roller for sliding mirror door.
29 Nov 2010
Denbighshire
Hello, we have an inbuot, wardrobe with big sliding doors. The wheel on one of them is broken and so we need a replacement part. The part is a Cox 21-717 21-767. The only one place i can find this is a US site that only ships to the US or Canada (am weaiting to hear back about if the y can ship to the UK, but the prives are quite high.
Would there be a Stanley or any alternative i could use??
thank you
Adjustable steel housing with non-ball bearing plastic roller
used on Cox 21 and 22 series mirror door systems.
Part may be stamped with numbers 21-717, 21-767, 21-718
Diameter: 1-1/2-inch
Height: 2-7/16-inch
Material: Plastic
Mount: Bottom ( Cox mirror door)
Roller Edge Type: Concave
http://www.allaboutdoors.com/product_info.php?products_id=25140
I recently came across sliding wardrobe DIY system as on the picture.
It is called "Ares" and did a trick for me when my wardrobe stopped sliding after some time. I replaced the gear with Ares myself and was surprised how easy it was. Its quiet and have a substantial wheels on the bottom with ball bearings inside (Heavy duty for domestic use). It came as a set of tracks and accessories for 3 doors and manufacturer claims 70kg per door rating. I think there is only one supplier who sells them in UK called Buller ltd.
phpThumb.php
http://www.bullerltd.co.uk/product/2330/ares-sliding-door-system
