I posted in the Plumbing area, but as this is really an electrical issue, I was advised to stick my query here...
I'm replacing our ancient 8.5kw shower with a newer model - same rating - and whilst checking the wiring etc. I discovered that the wall mounted switch (with neon light) on the external bathroom wall which supplies power to the shower, appears to be wired incorrectly...
The cable (which appears to be 10mm with L-N-E all braided) coming from the Consumer Unit is wired into the terminals on the switch labelled "out", whilst the cable from the shower are wired to the terminals labelled "in".
The shower has operated fine over the past 20 years, so I'm thinking it can't be all that bad...???
The neon light only comes on when the shower is switch on, as I believe it should.
Consumer Unit shows it wired to an MCB labelled B40 61/B40, so I'm assuming 40 amps...?
Anyone able to assist me...?
Dougie.
Dougie.
