- Joined
- 15 Jul 2015
- Messages
- 7
- Reaction score
- 0
- Country
I have a leaking radiator thermostatic valve. However whilst the compression fitting for the incoming water pipe is 15mm (bottom), the compression fitting going into the radiator appears to be larger, perhaps 20mm (see first pic).
I can't seem to find any replacement valves which aren't 15mm for both compression fittings. The one recommended as a replacement is a Drayton RT212, which is 15mm for both fittings.
The old valve does say the compression fitting which goes into the radiator is 1/2 inch, which is nominally 15mm, even though it appears larger as seen in the picture.
My question is will the Drayton fit on both the copper piping and the radiator, even though the existing valve appears to have two different sized compression fittings? The existing valve is over 40 years old!
Thanks in advance.
Thanks in advance.
