- Joined
- 7 Mar 2004
- Messages
- 298
- Reaction score
- 4
- Country
I need to replace some badly damaged floorboards in two of my bedrooms. The house is 170 years old and the boards are original. I would like to scour the reclamation yards to find something appropriate but that would take too long, the sizes are probably impossible to match exactly and most reclamation stock seems to be of poor quality - obvious damage and warping, etc.
I bought some boards from a timber yard but the sizing is confusing so I ended up with boards which are the correct width for one room but the wrong thickness.
Here are the sizes I’m looking for:
Thickness / Width
18mm / 195mm
18mm / 200mm
19mm / 300mm
19mm / 295mm
19mm / 195mm
As you can see, some of them are very wide and the sizes aren’t consistent across the floor other than the thickness i.e. each room may have boards with varying widths but they are all the same thickness.
1) Is there anywhere I’d be able to get these or do I need to have them cut to size?
2) If they need to be cut am I best off buying a planer/thicknesses (I already have some boards I could use if I could plane them to an 18mm thickness) and will a cheap one handle at least the smaller floorboards? Any recommendations?
Thickness / Width
18mm / 195mm
18mm / 200mm
19mm / 300mm
19mm / 295mm
19mm / 195mm
