I have encountered a problem whilst attempting to replace a British Gas PT5 progammable thermostat with a Homexpert (Honeywell) THR870CUK. A 15-minute job which has so far taken all day! (The combi-boiler is an Ideal Isar I'm afraid!)
The original PT5 has terminals 1, 2 & 3. The incoming red wire (with a brown sleeve) was connected to 1 and the yellow wire to 3 (2 is unconnected). According to the user guide, 1 is Common, 2 is Heating Satisfied and 3 is Call for Heat.
The Homexpert unit has terminals A, B and C. According to the scant instructions, A is switched and B appears to be a live feed. There are no more helpful decriptions given. C is unconnected and has a plastic break-off tab over the terminal to prevent a connection except under certain circumstances.
When I first connected the new unit, I connected the Red (brown) to A and the yellow to B. The boiler seemed to "kind of" work, but did not drop into standby when the target temperature had been reached, it did seem to work when the thermostat was set to Manual, but this may have just been a fluke.
When I looked again at the connections I decided I had them the wrong way around, so I swapped them After this, the boiler was supplying heat permanently, regardless of the thermostat setting.
I am now totally confused! My second configuration would seem to be the correct one (i.e. yellow to A and red (brown) to B), but neither configuration seem to work properly.
I am hoping you guys may have some suggestions (preferably clean ones!)
