Replacing a ceiling rose with just three red wires
29 May 2010
Help please. I have removed a ceiling rose to hang a chanderlier with a L/n/E connection but I have now realised that the wires from the ceiling are not standard.
The are three wires, one red, another red with a grean and yellow, another red with a bit of black tape on it.
I was epecting to see some black wires too.
How do I connect this to L/N/E?
black tape is neutral, green / yellow tape is earth , the red with no tape is live..
they've probably extended the too short cables with what they had and stuffed the connectors back up the hole..
Ok so that accounts for the single red, the red with tape, but what about the red which is shared with the earth wire?
Three grey wires coming in:
1, red
2, red with black tape
3, Contains two wires, one red one earth
Thanks.
Ah.
I think all of us, (see ColJack's post for example) thought that when you said "three wires, one red, another red with a grean and yellow, another red with a bit of black tape on it" you meant 3 wires, not 4....
:roll:
And perhaps when ColJack talked about "green / yellow tape is earth " you could have clarified then.
Is the red in the same cable as the green/yellow connected to it?
Do you have a multimeter, and know how to use it?
Sorry for be not being clear enough in the first instance.
the other red does indeed share the same cable as the green and yellow wire. Unfortunately I do not have a multimeter.
Thanks again
Give me strength.
connected to it?
You need a multimeter and some connectors to do some testing, will cost you about £12/15 from a DIY shed like B&Q, incidently, half or less than a call out from a sparky and you get the benefit of using the multimeter next time.
In the dimmer switch there are also three red wires and one earth.
Two reds are connected to 'c' the other one is connected to'L1'. earth is connected to earth.
PS. I've been trying to remember how they were connected in the ceiling rose. I'm almost certain that red (1) and red with black tape (2) were both connected to the 'N' point. the other red 3 was either connected to the 'loop' or 'line'. the old light fitting one wire was connected to 'N' and one to 'LINE'.
Hope this helps
