Replacing ballast in a CFL
18 Sep 2013
Hi, I have a kitchen light with a fried ballast, but its a Tridonic EC20 B90, and I can't find a trace of one anywhere on the internet. Presume they stopped making it a while ago. I was wondering if anyone knew where I might get one or, failing that if it was possible to use a different ballast as a replacement?
We're hoping to replace the whole kitchen next year, so really dont want to have to replace the light now.
What other info is there on the ballast, what size lamp?
Is it a 2D type lamp? Photos may help
The ec20 B90 was a choke for 18/24/26/28 compact lamps mainly.
A ec20 A50 does 18/24/26 compact lamps and should be ok if your running any of the 3 sizes,
cost about 10 pound
ec18 are easy to get, but depending on lamp size it may not be suitable
The lamp is a compact 20w, butterfly one. So I can use an A50 ok with it?
Not sure what you mean, if you mean a 2D lamp.
I only know of a 16 watt, 21 watt and a 28 watt in the smaller 2d sizes
Chokes are getting harder to buy nowadays, apparently the ec20 A50 is also phased out
The equivalent now is the ec18/20 A502K which does the same compact lamps as your old one
18/24/26/28 watt
Yeah 2D is what I meant. I've ordered an A50, hopefully will all work ok. Thanks for help
