Replacing cartridge for Mira 415 Combiforce shower
Discussion in 'Plumbing and Central Heating' started by tonysab, 4 Nov 2019.
  1. tonysab
    tonysab
    5 May 2004
    117
    Thanks Received:
    Country:
    Hi all, we have a Mira Combiforce 415 BIV shower which we have had for a number of years. Just lately the shower head has been dripping when the control is off. I have read this is likely to be the cartridge at fault (I can't understand how it could be the washer in the hose to head connector as also suggested, as surely if the control is off there should be no flow through the hose anyway?).
    Anyway my question is, as a very basic DIY-er - is it relatively easy to replace the cartridge, my concern is that the control knob is set on a tiled wall and although the hose and head are not built into the wall, can I get to everything I need to simply by undoing the control knob.
    Thanks in advance for any advice on this.
  2. Sponsored Links
  3. ReJect
    ReJect
    19 Oct 2019
    310
    Thanks Received:
    60
    Country:
    Yes it should be a fairly straightforward job to remove and replace the cartridge.
    Mira showers are designed well so that they are very easy to repair.
    I have never worked on that model, but generally it will only be a careful removal of the control knob parts to reveal usually 4 bolts to to remove cartridge.
    Obviously you need to have hot and cold water isolated.
    Need to put a heavy cover over shower tray to protect it and basic screwdrivers and perhaps going to need a slight smear of silicone grease for seals.
    • Thanks Thanks x 1
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
