I've just had my living room totally replastered with a new ceiling and have now come to fit a new ceiling light and replace the old dimmer switch for this light and just wanted to check a couple of things out, as what was supposed to be totally straightforward seems not to be.
I've got the lighting cable hanging through the ceiling (usual grey cable containing live neutral and earth), but on the wiring diagram for the ceiling light, it says as well as connecting these I should also be connecting a switch cable - I don't have this cable. The light fitted before only had 3 connectors, but this one has 4 - do I just leave the switch cable connector empty? (the ceiling light only works off one light switch if this makes a difference).
Also, I'm changing the old plastic dimmer switch for a chrome one. I thought this would be dead straightforward - just look what went where in the old one and replace like for like (which I can see how to do), but the new switch has an earth connector on the back. On the diagram supplied with it, it shows an earth cable connected to this as well as the one from the supply attached to the backplate. Am I supposed to fit an earth wire from the switch to the backplate, as one wasn't supplied, so do I need to supply it?
