Hi all, this is my first post on the DIYnot forums so please take it easy on me
I’ve done a little diy plumbing in the past but I’m still very much a novice.
I need to replace a pair of radiator valves and remove a basin/sink in our cloakroom, however, our central heating system is different to the one in our last house. We now have a traditional boiler (not a combi-boiler) in the garage and an emersion tank (one of those sealed cilinder units) in an airing cupboard upstairs. I believe we also have two water tanks in the loft, I assume ones for the hot water and the other is for C/H.
Can someone please confirm the steps below are correct:
1. Turn off the boiler and emersion.
2. Turn off the water mains to the house.
3. Disable the ball cocks in both tanks in the loft.
4. Drain the cold and hot water taps.
5. Drain the CH.
6. Remove radiator valves and fir new ones.
7. Remove basin, cut hot & cold pipes and fit compression valves.
8. Turn on water mains.
9. Re-enable both ball cocks and allow tanks to fill.
10. Turn on boiler and emersion.
Any suggestions or advise would be greatly appreciated.
5. Drain the CH.
