Hi
I'm replacing a towel rail in the bathroom to one a little taller and moving up to 250W.
The cable from the existing one goes through the wall into a FSU in another room.
The ring main is RCD protected.
I really want to have this on a timer so my question is which is the best option :
1) Replace the FSU with one with a timer (and 3A fuse)
2) Or should I replace the FSU with an unswitched RCD socket, put a plug (3A fuse) on the end of the towel rail cable and then plug that into a normal plug in timer which will then go in the RCD socket. Is having an RCD socket overkill as the ring main already gives this 30mA protection?
Thanks for your help
