Hi
Can someone help?
I am in the process of replacing a downstairs floor as it was in extremely bad condition – sloping off to one side. Having removed it I have found there is just over a meter drop to the ground level. I would like to simply line it and put boards down so as to utilise this as storage space as we have none at the moment (2 up 2 down with no loft space). To that end would someone be able to advise me on what size I Beam I should use to support the floor joists?
Originally there were several timber trimmers, most of the pillars have deteriorated or fallen over (hence the slope) and would make the space unusable as storage anyway.
The room is 4200mm x 3380mm. As I would like to use the original floor boards that I have saved the joists have to run the longest dimension. The Clear Span of the Beam would be 3200mm as there is a 180mm of stone foundation wall present before the partition wall is built on it. On the other side a 2 thick brick wall which I’ll have to remove a couple of bricks to insert the other end and strengthen to support the beam(s); depending on how deep the beam will be it will be either 2 or 3 courses above the stone foundation wall on that side. Firstly how much more than the 3200mm span should I have to support the beam at either end?
As I would like to maximise head room below the floor I would like to insert the new joists into the I beam rather than them resting on top. Notching them so the top of the joist is flush with the beam so floor boards can be laid on top. I’m thinking along the lines of two options
1. Using 50mm x 100mm C24 timber at 600mm spacing (6 in the span) would give me a dead load of 0.5 – 1.25 kN/m2 when the clear span is 1610mm. If I was to use 2 x I beams equally spaced across the longest room dimension what size would they need to be to give the same support as the joists? I would like to use a beam that is 100mm deep – do they exist? If so how wide and how thick would it have to be?
2. Using 50mm x 125mm C24 timber at 450mm spacing (8 in the span) would give me a dead load of 0.5 – 1.25 kN/m2 when the clear span is 2400mm. If I was to use 1 x I beam at the centre of the longest room dimension what size would it need to be to give the same support as the joists? For this I would hope for a beam that was 125mm deep.
I would prefer to use the 1st option as it would give a bit more head room to crawl around in and I’m guessing more structurally sound as the resulting loads would be spread across 2 beams?
I would be very grateful for any help on this subject. I can't afford a structural engineer.
Thank you in advance
Will
Can someone help?
Will
