One of my floorboards in a bedroom has a corner that has broken away and when you walk you can feel that area sink down a bit.
I believe this happened when previous owner made 2 bedrooms into one and damaged it when removing the sole plate as it was just a partition wall.
I’m not sure if it’s T&G but I suspect it is.
How do I remove just this one T&G board? It doesn’t go up to wall and is bang in the middle of the room.
The way my mind works for T&G is you start at one corner and keeping adding until the room is complete, so I don’t understand how I can just remove one board without removing the rest?
Also what type of flooring should I replace that one board with as I guess I can’t use T&G again, unless I remove all boards?
