Replacing hot water motorised Zone valve
10 Feb 2009
Bristol
I need to replace a two way 22mm motorised Zone valve as I have replaced the motor twice now and it has failed again so I’m assuming the valve is stiff for some reason.
It’s the valve that allows CH water into the HW cylinder to heat it. Is there a truck to create an airlock so I don’t have to drain the whole system down to change it?
Also I disconnected the wiring as the motor was making an annoying buzzing sound I manually opened the valve but have no HW does the valve need to be in the circuit to allow the controller to fire the boiler?
Thanks in advance,
Jon
1. If it is a vented hot water system, you will need to drain down below the level of the valve, unless you can freeze the pipes.
2. If it is an unvented hot water system, you are not allowed to work on it. The valve is part of the safety system and requires a G3 registered technician.
3. The manual control normally does not go over far enough to operate the micro switch which fires the boiler.
Hi
Many thanks, it’s a vented system so I shouldn’t have even changed the valve motor?
Jon
If open vented you can bung the system so you don't have to drain, if it's pressurised you won't have to drain
